Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Winch battery?
Bud in WV
05-23-2013 04:56:00
I use a wench to drag logs onto an 18 ft trailer to cut up for firewood.
I used light welding lead from the truck battery to the rear where I plug the wench lead into a 50amp stove outlet.
Keep the truck idling and you battery doesn"t die. I don"t use the wench enough to justify a battery that will probably be dead the next time I need it and the welding lead, outlet and connectors cost considerably less than a heavy battery does.
TyWrap the welding leads to the frame and use red electricians tape to identify the hot leg.
The local electrical supply house had welding lead for a good bit less than the welding supply, too.
36 coupe
05-25-2013 05:52:41
 Re: Winch battery? in reply to Bud in WV, 05-23-2013 04:56:00
She must be pretty strong.
05-23-2013 05:14:02
Keep in mind also that only the hot lead has to be full length. You can ground the connector at any handy point on the frame.
Bud in WV
05-23-2013 13:28:58
 Re: Winch battery? in reply to Fawteen, 05-23-2013 05:14:02
Wish I"da remembered that last year.....woulda save $25! Brain f*rts happen.
