TractorLinks.com
Tool Talk Discussion Forum
Re: old yazoo mower parts
Stick welding
04-27-2013 09:05:06
Is that housing cracked and the hole is wallowed out? It looks like it's aluminum. Take the bearings out and a good TIG welder could fix it good as new.
john niolon
04-27-2013 09:15:03
 Re: old yazoo mower parts in reply to Stick welding, 04-27-2013 09:05:06
yep... it's aluminum... the only weak part on the whole machine. the bore isn't wallowed out or oversized. if we could clamp it back in place and get it level again... a tig repair might work... I just need to find a tig man.
repairing or building a new one is my next option... I thought about some schedule 80 piped bored or honed out to fit the friction hub o.d. and build a stand under it... my up/down measurements aren't critical as long as I keep the chain tight... it wouldn't hurt to build in a little slack for chain tightening...
these old mowers were bad to let the chain jump off when mowing on a slope.. and that's a pia.. I'm searching on the internet now for some kind of 'housing' for a bearing that might work...
Stick welding
04-27-2013 17:49:54
 Re: old yazoo mower parts in reply to john niolon, 04-27-2013 09:15:03
Find someone that does aircraft work or works on snowmobiles and motorcycle castings. Aluminum is easy to work on when you know what you're doing. The trick is finding someone who actually knows what they're doing. Don't give it to some guy that thinks he might be able to do it or will try to fix it. I know a couple guys that could do it but I'm a long way away.
