how fast does your cement mixer run?
jCarroll
Location
mid-Ohio
Just bought one of the old style mixers (in good shape) at an auction. The motor is 1725 rpm, has a 3" pulley, driving a 14" pulley on the pinion shaft. So the pinion is turning at 370 rpm.
Just seems like the mixer drum is turning faster than it should (needs to). Nothing particularly wrong - just really whirrs.
How fast does your run?
I"m using an old Montgomery Wards mixer that will do about a wheelbarrow full per batch. I would guess the drum is turning 20 rpm. I think the motor pulley is 2 inch, maybe smaller.
Bob
Mine runs too fast. They won't mix properly if they run too fast, and I suspicion yours is too fast also. Centrifugal force holds the concrete to the drum, rather than letting the paddles stir and drop it as it should. I can't reduce the drive pulley size on mine, so it's time to build a jack shaft speed reducer.
I found a 1250 rpm motor at a yard sale, works much better then the 1750 motor that was on it.
Never did the calculations but the one I use was way too fast.Pulled the pulley off the motor and took it to the hardware store and bought the smallest replacement I could find.Works much better now.
370rpm is way too fast. You should be running 20-30 rpm. Here are 2 electric mixers from Northers Tool and they run 26 and 30 rpm.
http://www.amazon.com/Northern-Industrial-Portable-Cement-Mixer/dp/B001A2VCAO
http://www.amazon.com/Northern-Industrial-Electric-Cement-Mixer/dp/B001A2XHWK/ref=pd_sim_sbs_hi_6
Gilson mixers, which is owned by Marshaltown now, run at 25 rpm. Check out the current models and even look manuals for the older units on their website. http://www.marshalltown.com/Mixers.aspx#
Here is a pulley chart to help you pick new pullies to get the right speed. http://www.csgnetwork.com/pulleybeltcalc.html
Thx 4 the Marshalltown link. That gives me "hard data" to use since
mine is a "twin" to their 300 model.
BTW, my pinion turns at 370 rpm, not the drum.
Mine will run 64 MPH. :lol:
Bob.
370 is at the pinion, not the drum speed.
What you gotta do is count the teeth on the drum and figure out what the gear reduction is there. 10-tooth pinion, and 120-tooth drum makes for about 30RPM at the drum, which is too fast.
