TractorLinks.com
Tool Talk Discussion Forum
old yazoo mower parts
john niolon
04-27-2013 04:55:26
Hi Guys My reliable source for Yazoo mower parts doesn"t have what I need... Mower is a Yazoo SV-22-b 22" big wheel mower from the late 70s - early 80s. I"ve used my last spare part off my parts mower and need a "friction hub housing" to get it moving again.... does ANYONE know of a parts source on these old decks... old lawnmower shops, graveyards, parts houses that might have this discontined part ?? I hate to see this old warhorse die.. I can email pics if needed thanks
John
Martin Reece
04-29-2013 19:00:21
 Re: old yazoo mower parts in reply to john niolon, 04-27-2013 04:55:26
Hi Ronnie,
Try kunkels mower service in Kutztown Pa. 1 610-683-7743 I have always had good luck with older Yazoo mower parts there.
Martin
ronnie graves
04-28-2013 21:38:46
try mississippi engine in jackson miss ,
you know where that yazoo was made ?
john niolon
04-29-2013 04:42:17
 Re: old yazoo mower parts in reply to ronnie graves, 04-28-2013 21:38:46
thanks Ronnie
I'll call them this a.m.
j
riccumming
04-27-2013 09:43:56
If thats old, what doe's that make my 50'S GRAVELY?
john niolon
04-27-2013 11:15:40
 Re: old yazoo mower parts in reply to riccumming, 04-27-2013 09:43:56
that makes it a dang good mower, Ric I've got a new Gravely zt54 zero turn... I love that mower
Stick welding
04-27-2013 09:05:06
Is that housing cracked and the hole is wallowed out? It looks like it's aluminum. Take the bearings out and a good TIG welder could fix it good as new.
john niolon
04-27-2013 09:15:03
 Re: old yazoo mower parts in reply to Stick welding, 04-27-2013 09:05:06
yep... it's aluminum... the only weak part on the whole machine. the bore isn't wallowed out or oversized. if we could clamp it back in place and get it level again... a tig repair might work... I just need to find a tig man.
repairing or building a new one is my next option... I thought about some schedule 80 piped bored or honed out to fit the friction hub o.d. and build a stand under it... my up/down measurements aren't critical as long as I keep the chain tight... it wouldn't hurt to build in a little slack for chain tightening...
these old mowers were bad to let the chain jump off when mowing on a slope.. and that's a pia.. I'm searching on the internet now for some kind of 'housing' for a bearing that might work...
Stick welding
04-27-2013 17:49:54
 Re: old yazoo mower parts in reply to john niolon, 04-27-2013 09:15:03
Find someone that does aircraft work or works on snowmobiles and motorcycle castings. Aluminum is easy to work on when you know what you're doing. The trick is finding someone who actually knows what they're doing. Don't give it to some guy that thinks he might be able to do it or will try to fix it. I know a couple guys that could do it but I'm a long way away.
charlie n
04-27-2013 08:28:32
Try here.
http://www.jackssmallengines.com/
john niolon
04-27-2013 08:46:35
 Re: old yazoo mower parts in reply to charlie n, 04-27-2013 08:28:32
thanks Charlie.... jack's doesn't do anything this old... lot's of dealers of parts out there but very few carry the really old stuff..
j
