Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: can a 4 prong trailer harness run electric brakes?
Leroy
04-26-2013 17:38:10
If he is doinf that then it is because he doesn't have lights on the trailer. With lights they take up the 3 hot spots and the one ground spot so he is going without lights to have enough wires to feed the brakes.
t1
04-27-2013 09:37:36
 Re: can a 4 prong trailer harness run electric brakes? in reply to Leroy, 04-26-2013 17:38:10
He could have lights, sort of lol.
If you run your brake controller through the 4 way plug, to power the brakes, then splice your trailer brake light wires to the electric brake wires, you still get brake lights when the electric brakes are applied. maybe not as bright as you or I would want them however. and its certainly NOT the way I would do it.
Now, turn signals, thats something else. many vehicles flash the brake light bulb, so if not wired right, you could end up pulsing your brakes too. That assumes of course, that turn signals are even used. so many people today have no idea what that lever on the side of the steering column is for...
willys53allis
04-26-2013 17:56:26
It's just the opposite, lights but no electric brakes .
Leroy
04-27-2013 06:21:05
 Re: can a 4 prong trailer harness run electric brakes? in reply to willys53allis, 04-26-2013 17:56:26
If he is using brakes on a 4 wire then he cannot have lights but they are made for the lights and not brakes. Brakes only would work with a 2 pole coupler, think you might have missunderstood what I was trying to say.
504-1
04-27-2013 11:29:22
 Re: can a 4 prong trailer harness run electric brakes? in reply to Leroy, 04-27-2013 06:21:05
Even if you wired brakes through a 4 pin,they are not heavy enough to carry the electric load for very long. Re wire the trailer and do it right.
W_B
05-02-2013 11:18:04
 Re: can a 4 prong trailer harness run electric brakes? in reply to 504-1, 04-27-2013 11:29:22
Agree. Not that hard, even a dummy like me can figure it out. I wired one for a friend in the parking lot of a Tractor Supply in an emergency situation (regular tow vehicle broke down and substituted the pick up truck).
W_B
05-02-2013 11:17:08
Darn double post!
This post was edited by W_B at 11:20:44 05/02/13.
W_B
05-02-2013 11:17:08
504-1 said: (quoted from post at 19:29:22 04/27/13) Even if you wired brakes through a 4 pin,they are not heavy enough to carry the electric load for very long. Re wire the trailer and do it right.
Agree. Not that hard, even a dummy like me can figure it out. I wired one for a friend in the parking lot of a Tractor Supply in an emergency situation.
This post was edited by W_B at 11:18:39 05/02/13.
