TractorLinks.com
Tool Talk Discussion Forum
Re: air compressor
Rod (NH)
04-26-2013 06:59:13
Two stage and 3000 psig discharge pressure doesn't compute as far as I'm concerned. Are you sure of that? Two stage compressors would generally be limited to discharge pressures of less than a couple of hundred psig to keep the compression ratios per stage down and limit temperatures to avoid damaging materials used. In fact, most two stage units max out at 175 psig rated because of that. Typically, such a high discharge pressure would require several stages - e.g. four or five and the capacity would be in cfh not cfm for any reasonable horsepower input. Very low flow and very high pressure capability would have no use around a farm shop. Best to limit it to the service it was designed for - filling dive tanks.
Steve in VA
04-26-2013 10:23:42
 Re: air compressor in reply to Rod (NH), 04-26-2013 06:59:13
Rob,
Yup, the manual cites etiehr 2000 or 3000 psi. I agree with you even in my limited experience that doesn't sound right. I'll report w/ pictures once I get it sprung out of the Suburban.
