1941 Oliver 60 Standard
Hi;
I have 1941 Oliver 60 Standard After a severe back fire, I no longer have rotation of the distributor shaft.Viewing into engine block the main gear does not rotate when engine is cranked. I thought it may be timing chain but the manual I have does not show a timing chain. Is it a gear timing set up?
Help! Thanks.
Its been a while but it could have sheared the pin on the distributor shaft gear. Distributor is run off the cam shaft if I remember right. Hope this helps. Bandit
It is timing gear, no chain. Take the distributor out and see if the cam shaft turns when you crank the engine over.
