Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Basic AC Power Systems
Dusty MI
04-25-2013 09:42:05
A 3 phase motor can be reversed instantly, that's so fast that you can't see it happen or see that it's turning the other way.
In most cases the voltage to ground is half of what the nominal is, that is if the voltage is 480 between the legs, it's 240 to ground. In a home 120/240, it's 120 to ground. It's surprising the Mr. home owner will try to work on something that's 120 but will not touch 240, even though he is more likely to get bit on one leg to ground, 120 volts.
Along that line the isolated/floating 3 phase that we were talking about, most often 480, if one leg does go to ground, then it's 480 from each of the other legs to ground.
Where as a 480 Y is 277 to ground.
