TractorLinks.com
Tool Talk Discussion Forum
Re: Hauling Oxygen Bottle
RodInNS
04-22-2013 21:41:55
Mile and a half might be a bit far... but you can go on youtube and watch video of various propane and acetylene storage facility fires... particularly propane... and they launched cylinders several thousand feet. Not hard to see the distance given they're traveling as a ball of fire. It's a little different than compressed inert gas... but it's still stored energy.
I've seen 20# BBQ tanks launch 20 feet in the air when they blow.
Rod
sflem849
04-23-2013 04:15:51
 Re: Hauling Oxygen Bottle in reply to RodInNS, 04-22-2013 21:41:55
This one occured a few miles from my house. You can see a tank launch from the storage tank up and to the right. I don't remember if it was a 20# or 100# tank. The truck driver was filling the delivery truck from the storage tank and started a fire. It burned for a while, but BLEVE'ed before they could get the storage cooled off. The explosion consumed so much oxygen that it pretty much put the fire out.
http://www.youtube.com/watch?v=uXnDjrNbwN0
JMOR
04-23-2013 06:49:59
 Re: Hauling Oxygen Bottle in reply to sflem849, 04-23-2013 04:15:51
Seems that we just maybe digressed a tiny bit here. Moving from broken off valve propulsion over to explosions hurling objects. The big WWII guns used explosive charges to hurl 1000+ pound objects 20 miles. That is not a broken tank valve though!
RodInNS
04-23-2013 07:47:40
 Re: Hauling Oxygen Bottle in reply to JMOR, 04-23-2013 06:49:59
The principle behind it is exactly the same...
Rod
JMOR
04-23-2013 08:07:39
 Re: Hauling Oxygen Bottle in reply to RodInNS, 04-23-2013 07:47:40
Not.
RodInNS
04-23-2013 08:33:46
 Re: Hauling Oxygen Bottle in reply to JMOR, 04-23-2013 08:07:39
You're releasing energy from a pressure vessel.... that to me is exactly the same principle. Wether it's static pressure from high pressure containment or the gaseous expansion/explosion of a fuel... make little difference to the projectile.
Rod
JMOR
04-23-2013 09:11:18
 Re: Hauling Oxygen Bottle in reply to RodInNS, 04-23-2013 08:33:46
Quoting Removed, click Modern View to seeObserve the difference for yourself, don't take my word for it. 1) release the contents of a 20# (larger if you like) propane tank into your living room.....observe the result of pressure release/gas expansion. 2) Repeat same, except this time throw a match into the living room. Did you see any difference in the amount of gas expansion? Not the same was it?
RodInNS
04-23-2013 17:49:59
 Re: Hauling Oxygen Bottle in reply to JMOR, 04-23-2013 09:11:18
You must really think I'm some kind of idiot or something...
Before you spend any more time shooting your mouth, go read about BLEVE... watch some flaming LP cylinders fly, etc.
If you heat a tank that's storing a compressed liquid, short answer is you have a bomb waiting to vent somewhere. That's an entirely different scenario than venting an LP tank and nominal temperatures. As far as igniting vaporized propane... it's got nothing on pressurised propane. Once again, the basic principle of releasing stored energy is EXACTLY the same.
Rod
JMOR
04-23-2013 18:15:26
 Re: Hauling Oxygen Bottle in reply to RodInNS, 04-23-2013 17:49:59
Quoting Removed, click Modern View to seeIt is beyond me, as to how you can claim, " Once again, the basic principle of releasing stored energy is EXACTLY the same. ". There is, in the one case, the energy of compression of a gas, whereas in the other case the energy of combustion accompanied by much, much greater expansion than simply releasing a compressed gas. Why don't you run your tractors on compressed air instead of burning fuel? "Exactly" is where you are falling down.
RodInNS
04-23-2013 18:20:44
 Re: Hauling Oxygen Bottle in reply to JMOR, 04-23-2013 18:15:26
The principle... is that energy is being released from a storage vessle creating thrust. Sorry I forgot to point that out. It works the same way in both situations.
Rod
JMOR
04-23-2013 18:24:54
 Re: Hauling Oxygen Bottle in reply to RodInNS, 04-23-2013 18:20:44
Quoting Removed, click Modern View to seeWe probably both understand. Recognizing that energy/expansion due to combustion is far different than releasing the energy of compression of a gas is key to not being 'exactly. Have a good one!
Stick welding
04-22-2013 22:02:39
On a wet grassy field they could go a long way.
