Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Welding rod recommentation for wear surface build-up
Andy Wickiser
04-22-2013 17:57:28
Hey Stick welding, I think you put me on to something. The plate was magnetic. Then I bumped it with a 4 1/2" grinder with a cutoff wheel. Produced a really long orange spark stream with vivid bombbursts. I think this is cast low-to medium carbon steel! The spark stream from a 6" I-beam, that happened to be next to the plate produced a similar spark stream. The funny thing is I took the magnet to the cheek plates and the were nearly non-magnetic ... probably those do have a high manganese content. Based on these findings I think I'll run a test bead with plain jane 6011 and if it looks good I'll proceed with a buildup. Thanks!
Stick welding
04-22-2013 19:26:24
 Re: Welding rod recommentation for wear surface build-up in reply to Andy Wickiser, 04-22-2013 17:57:28
I wouldn't use 6011. Try some of the hardfacing on a scrap piece to set your heat. If it looks good then try a little on your plate.
Andy Wickiser
04-23-2013 04:43:01
 Re: Welding rod recommentation for wear surface build-up in reply to Stick welding, 04-22-2013 19:26:24
Yeah, maybe I'll get something from the Lincoln Wearshield BU family, that seems like it would be about right.
Copyright © 1997-2015 Yesterday's Tractor Co.
