Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Rosebud torch
04-20-2013 07:25:06
How big do I need?
Stick welding
04-20-2013 13:10:43
 Re: Rosebud torch in reply to Leroy, 04-20-2013 07:25:06
I'd GUESS you have a 75 cu. ft. acetylene. Size of oxygen makes no difference. What do you have to heat? Maybe a cutting tip would be hot enough but if you only need to heat for about a minute, you should be OK. If you have a lot of heating to do, you'll need a bigger cylinder. Look on the net for a chart for your brand of rosebud and it will tell you how much gas it consumes.
04-20-2013 16:49:05
 Re: Rosebud torch in reply to Stick welding, 04-20-2013 13:10:43
Was just wondering, will get by as I have been with it for the last 33 years using the biggest welding tip. This is just what was sold as a standard farm torch at that time and at that time I had no idea they made more than one size tank.
04-20-2013 18:58:47
 Re: Rosebud torch in reply to Leroy, 04-20-2013 16:49:05
A #6 tip size designation is not usually a rosebud multi-flame heating head, but a single flame welding tip for oxy/acetylene gas welding or brazing rated by the mfg's recommended metal thickness range. A rosebud is rated in BTU output and it is very important to consult the mfg's operating instructions for the size of rosebud being used. For acetylene, if the torch draws more gas than can be vaporized by the tank, it will draw acetone which can ruin a regulator and the gas hose. Large acetylene or Mapp rosebuds may require manifolding two fuel gas cylinders together. The size of hose is also important, I'd hate to guess how many Mapp or natural gas rosebuds I've seen blown up by welders or other people in the shop when connected up to a too small regulator or hoses or maintenance had reduced the pipe size to the regulator. Too low of a flow will cause the torch to overheat, melting the flame slots which closes them off and the torch will begin to bang like a machine gun, blowing molten brass out the end. This can get dangerous because large tips need velocity to remain cool enough not to melt the head itself. The other problem I've seen on more than one occasion is a natural gas, recessed face rosebud, hooked up to a Mapp tank. Mapp gas has much more BTU/volume, quickly overheating the natural gas rosebud, again with the same "machine gun" melting brass flying results.
Always match the tip size and type with the manufactures instructions. I just bought a new Smith rosebud for the race car shop and even the individual torch head came with the instruction book with tables of information showing which tip goes with which size torch handle.
If the #6 tip is a one hole, single flame, welding tip, it isn't going to be a problem using it on medium duty regulators. I hate to talk down to people, but after all these years in fabrication, I can't believe some of the things experienced welders do and then wonder what happened.
Stan in Oly, WA
04-21-2013 11:22:22
 Re: Rosebud torch in reply to forty40, 04-20-2013 18:58:47
I didn't feel like you were talking down to anyone at all. I found your explanation to be very clear and informative. Based on your description of what can happen when the gas flow is adjusted too low, I think I have to go back to the college welding shop and check the condition of the 1-1-101 cutting tip I was using yesterday. I was in a hurry and I knew that I hadn't adjusted the acetylene flame high enough, but I thought, apparently mistakenly, that I could use it as if it were a smaller flame. My material was thin, and what I really needed to do was to change out the tip for a 00 or 000, but I didn't. After cutting for a short time, the torch started machine-gunning. I stopped using it, although not that very instant, I'm sorry to say, and when I was putting the equipment away, the tip and the nut were too hot to touch without gloves and the torch itself was hot even a few inches down from the tip. I hope I didn't ruin it.
So no, please don't think that you're talking down to anyone. I'm experienced enough that I teach this stuff to people who have no experience at all, and it seems like every day I find out that there are important things I don't know.
Stick welding
04-21-2013 12:43:41
 Re: Rosebud torch in reply to Stan in Oly, WA, 04-21-2013 11:22:22
Stan, you can turn the acetylene down a little but too much acts the same way as not having your pressures high enough on a rosebud. You get backfiring. If you have lots of soot with the acetylene flame, go to a smaller tip.
Stick welding
04-20-2013 21:11:34
Rosebuds can be a #6 as well as a welding tip. The number usually relates to the size of the preheat holes or the amount of gas they flow. In Victor a #6 heating tip is rather small while a #12 is a big rosebud. Purox will use a number like 70 which is how much gas it will flow. I think in CFH but would have to check to be sure. I've seen some scary things welders have done too.
04-21-2013 07:08:04
 Re: Rosebud torch in reply to Stick welding, 04-20-2013 21:11:34
I was looking at a Hobart no.6 at TSC and it said Victor compatable, my outfit is the cheaper Victor line. That is all that was on the package. Except that it would work on both acetelene and LP. When I bought this outfit new it came with 3 sizes of welding tips and 3 sizes of cutting tips. Last year during the shortage I bought the LP cutting tips but was having trouble using them. Did not use torch at all over winter and just got out last monday and used some, thought I had over a half tank of oxygen last fall, nod not check pressure in tank untill was done and ready to shut off and gauge was peged at 0 and in picking up hose I felt wind that should not have been there. Checking I found a rodent had put a tooth thru it so had to buy a new hose. And just about everything out there is acetelene only, lp rated at only one store and so high priced could not afford it, that is my gas supplyer and he was one that said didn't think tank would handle one but they cost about $165, that one I seen at TSC was $70 and same tip at Rual King is $30 so Ican't see where the welding shop one would be so much better than the hobart one for way over a hundred dollars more.
