Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Build me a tool box
Rob Mo.
04-19-2013 12:43:11
I was given a project @ work the other day. I was asked to take a 20" Craftsman tool box & stock it full of tools that can be used for simple fixes on automotive. I got on my list screw drivers, wrenches (1/4" - 1" & 8mm- 19mm"), Channel lock pliers, Side cutters, neddle nose pliers, lineman pliers, & adjustable wrench. I can't forget duck tape. any other ideas?
Gordon in IN
04-21-2013 21:44:09
 Re: Build me a tool box in reply to Rob Mo., 04-19-2013 12:43:11
Digital or dial caliper. Notebook and ball point pen. TWO 15mm wrenches (most metric sets do not have 15mm size). 1 1/16 and 1 1/8 inch wrenches. Package of fuses. Penetrating oil. Spray starting fluid. Silicone grease. Tape measure. Band Aids. Waterless hand cleaner. Safety glasses. Gloves.
Buzzman72
04-21-2013 04:51:35
Don't know how you'd get by these days without a set of those fuel/AC line connector tools, and the tool/specialty pliers used on Weather Pack electrical connectors.
Or a serpentine belt tensioner tool.
Or a multimeter.
And that's just for starting out to do simple tune-up and maintenance.
justanothercase
04-20-2013 22:45:39
5 gallons of gas and a box of stick matches.
Jose bagge
04-20-2013 14:34:00
This made me smile because I've interviewed guys applying for a mechanic's job who had less. Had one "master t.ech" applicant show up on day one with his tools in a drywall bucket
Fepo
04-20-2013 10:52:52
c"mon guys...... 6 beers an ice pack and a cell phone.
1- open box
2- take out beer and cell phone
3- close box and sit on it
4- open beer and call someone!
Steve in VA
04-20-2013 10:36:41
we are talking about a self-propelled ride-on tool box here, right? maybe even diesel. with a cup holder.
J.Wondergem
04-20-2013 06:50:25
I'll bet your head is spinning now. That's a bigger pile of tools than would fit in a chest.
Steve in VA
04-20-2013 04:53:44
I'd pack a small tarp to keep all the little dropped bits out fo the grass/gravel. Light is also handy. maybe even mag mount.
JohnDeereJimOhio
04-20-2013 04:25:56
Snap ring pliers are always handy
MarkB_MI
04-20-2013 04:08:14
1/4" drive socket set with Torx bits. Metric and standard allen wrenches. Magnet with telescoping handle. Stiff-blade putty knife for scraping gaskets and removing crud. Toothbrush-sized wire brush. Small roll of emery cloth. Utility knife.
Dave in Tx
04-19-2013 21:11:22
Put a 6' double stacked box on each side of that 20" box and fill them full of every tool you can imagine and you won't have to borrow many to change a water pump or a set of plugs on most of the new vehicles.....
rustred
04-19-2013 20:31:11
i think that was an april fools joke! just what is a simple fix on todays auto's? you need specialty tools. maybe keep the duct tape.
magpiene.
04-19-2013 20:01:59
Left handed monkey wrench. Don't forget the muffler bearing pullers!!!!!!
bill b va
04-19-2013 18:42:55
adjustable metric wrench
dr sportster
04-20-2013 12:14:37
 Re: Build me a tool box in reply to bill b va, 04-19-2013 18:42:55
I got one that is amazing one side says 10 " and works on standard and flip it over and it is in Milimeters and works on metric. One of my favorite adjustables.
Stick welding
04-19-2013 17:38:58
Put a cell phone in it with the name of a good repair shop. LoL Sorry couldn't resist. Are you new to mechanics? Maybe someone at work could give you an idea? A socket set and a basic multimeter would be good to have.
redtom
04-19-2013 17:31:19
You need a bigger box
Tims A
04-19-2013 17:09:01
BFS, Big Frekin Screw driver, a head light the kind you wear on your head for work light.
circus
04-19-2013 16:59:24
Lighter Marker Rag
Scott in SF
04-19-2013 16:44:30
Utility knife
NCWayne
04-19-2013 15:27:26
If your doing automotive stuff nowdays then you definately need the torx bits. The best thing I have found to keep in a 'general repair' type box is one of the sets that has multiple bits that fit a 1/4 inch hex handle. Find a set, or if need be two sets, to insure that you have both the torx, allen, straight and phillips, and hex bits. Add in a 6 in one screwdriver, a 1/4 drive rachet, a pair of pliers (I like to just use vice grips because of their verstility, especially one with the wire cutter part at the joint), a 6 and 10 inch adjustable wrench, and you can do many simple repairs. On top of that a pair of wire cutters, a roll of Super 33 electrical tape, a few zip ties, a small roll of like 150 grit emery cloth, and an inexpensive electrical meter (on top of, or in place of the test light as it will do the lights job and then some). Then throw in a few different guage wires at least 36" long, and a handful of crimp ends (but splices, ring terminals, spade terminals, etc)along with a crimp tool. With these simple tools there won't be many minor repairs you can't handle.
OLD TIMER
04-19-2013 15:12:32
DON'T FORGET THE BALIN' WIRE!
WGWKy2
04-19-2013 15:00:09
Some guys here only carry a cell phone, to call a friend with tools.
dr sportster
04-19-2013 14:55:03
3/8 drive allen wrenches or hex keys. Torx is mentioned. Invisible glove hand coating. Make sure your metric set has 18 mm in it.
jackbrit3
04-19-2013 14:46:51
12 volt test light, very fast, and easy to use
Chris(WA)
04-19-2013 14:37:10
A socket set and in this day and age a diagnostics code reader.
dandeere
04-19-2013 14:29:49
chisels, punchs, hacksaw,allen,torx,fuses,
loko17
04-19-2013 14:23:07
Zip ties (wire ties) are always good to have.
Wile E
04-19-2013 13:43:53
Dont forget the BFH..........Big, ****ing Hammer.
You cant fix anything without a BFH.
old
04-19-2013 13:26:55
Vise grips for sure. Electrical tape,some wire, say in 10-14 gauge sizes
johnpop1
04-19-2013 13:03:51
need to remember things like measuring devices, and a simple volt-ohmmeter. a roll of good electrical tape and maybe some jb weld.
