machining tools
not mine but on St.Louis CL
http://stlouis.craigslist.org/tls/3707481867.html
http://stlouis.craigslist.org/tls/3717661967.html
(quoted from post at 08:24:55 04/18/13) What would I use a surface grinder for? (in tractor restoration or general fab work)
A surface grinder could possibly be used for truing up a cylinder head, or mabe even resurfacing a manifold, but that milling machine would do all of that plus a whole lot more.
True, but I'd rather grind a head than mill it. So many mills are way out of tram (although Bridgeport styles are easy enough to do) you get a step between passes of a face mill. I'm spoiled, I've got free reign over just about any piece of equipment ion the shop at work. CNC mills, manual lathe, surface grinder, blanchard grinder, welders, etc...
I've done lots of personal projects at work simply because I can do a better job with some of what I have available to use. Some because it's climate controled, and winter's a good time of year to do these things.
Just today I brought home some replacement uprights I welded up for supporting drag sections on the cart that I made, and a sprayer pump I cleaned up there and put new parts in. Here are some of the things I've done in the shop, atleast partially.
Donovan from Wisconsin
Don, next time you are near Janesville you can show me how to use my surface grinder. The only use I have found so far is flattening the worn oil pump plate on a Farmall. This surface grinder is too small for a cyl head. The mag base is probably only 6"x12"
That is a pretty small one. We've got 2 at work, 1 being pretty small and all manual, and the other can be run on full auto and if I remember right, the table is something like 12" x 18" or 20". Still a little small for an engine head.
We have 1 machine in the shop that is very accurate and straight. The boss had the guy on that machine dust the top of his 5.9 cummins (putting an honest 1000 HP to the wheels) and cut in some grooves around each cylinder for sealing the head to the block.
Not really much to using a surface grinder, just use a diamond tipped wheel dresser on the wheel to make sure it's true. Take small cuts and keep it moving. Probably not a big enough wheel or critical enough stuff being done with it to worry much about balancing the wheels.
The surface grinder looks like a Brown & Sharpe. I have one that looks just like it, but only gave $250 for mine. IMO, he is awful high on price.
I might only use mine a few times a year but I'm sure glad to have it when I need it. I have a cheap spindex and a set of 5C collets that work great for grinding pins to size.
(quoted from post at 10:30:17 04/20/13) The surface grinder looks like a Brown & Sharpe. I have one that looks just like it, but only gave $250 for mine. IMO, he is awful high on price.
So it isn't just me that thought it was pretty steep. I paid less than $500 total for my Tree mill and my surface grinder. I didn't know if I got a really good deal or he was really high.
What should a 12.5x48 Cincinatti lathe be priced at? Fairly well tooled with a couple chucks and a live center. It has a 4 jaw pictured, but I would assume there is a 3 jaw with it. I know about boring bars or a drill chuck etc.
(quoted from post at 14:26:32 04/20/13) Wile E do you know what a surface grinder is?
So I am not crazy? I wasn't sure how you would sharpen stuff on it. Other than make stuff REALLY flat.
(quoted from post at 13:50:19 04/20/13)
My opinion is that a lathe of that age should not be priced at any more than about $500, but then I'm still looking for one.
A 4 jaw chuck is pretty much worthless for general use. Only time I've seen a 4 jaw used was when the machinist needed to trun a square hunk of iron into a round hunk.
Loren, you and I are not so different. :lol: The only thing that makes this one worth more is coming very well tooled.
I have heard that 4 jaws can hold a part straighter, but are harder to get the item straight in. Make sense?
