TractorLinks.com
Tool Talk Discussion Forum
ratchet grease
bobpa
04-15-2013 23:06:21
Hello. I bought an old snap on ratchet at a flea market. I took the gear out and cleaned out the old grease. Would a dab of wheel bearing grease work OK or is there something better for this application? Thank you.
bobpa
04-17-2013 19:52:58
 Re: ratchet grease in reply to bobpa, 04-15-2013 23:06:21
Thank you for all of the information. I appreciate your help.
Bob
mdtractormechanic
04-17-2013 16:13:33
 Re: ratchet grease in reply to GordoSD, 04-15-2013 23:06:21
White Lube
greygoat
04-17-2013 09:33:56
A drop of Corn head oil!
JD Seller
04-17-2013 08:16:40
I would not use any kind of grease. I clean mine out and then soak them in new diesel fuel. After they are cleaned out this way and the diesel fuel will act as a light lube then they will work easy. Then if they get turning hard I just hold the head under some parts cleaner and ratchet it until it moves free. Then blow it out with air and lightly lube it again. If you use the ratchet on a regular basis then it should not need much lube. Most of the stuff I work on is greasy and oily anyway so most of my tools are well lubed anyway. LOL
The light sewing machine oil works well to lube them with. It is a very light oil that does not seem to gum up.
ken combs
04-17-2013 07:36:45
Get some engine assembly lube from the parts store. Really slick, and works great in tools.
Russ from MN
04-16-2013 15:07:58
Grease will prevent the pawl from going to the bottom of the gear teeth, and it will slip more. Use oil as stated.
soundguy
04-16-2013 10:35:30
i use molly grease with a lil graphite in it.
Revredneck
04-16-2013 07:02:56
My Snap On dealer used to tell me to soak the ratchet head in engine oil. Grease will gum it up and cause it not to work properly.
Good Luck and God Bless
glennster
04-16-2013 06:16:03
any of the tool trucks will have the grease in small tubes. there is a special small grease gun for injectin grease into air rachets and 90 degree air grinders. in a pinch, you can use engine assembly lube.
Gary from Muleshoe
04-16-2013 04:15:45
I have used plumber's grease and it seems to be fine so far.
Chris(WA)
04-16-2013 01:02:14
That might be a little thick in cold weather. Silicone grease would be my choice or even some vaseline.
