Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Air conditioner question?
missouri massey man
04-14-2013 09:55:08
The simple answer to your question is a 10,000 btu A/C is 5/6th ton. And compared to your 36,000 btu (three ton) A/C it is 5/18ths of that.
Bob is correct, but usually a ton is used to describe the amount of heat transfer required to freeze one ton of ice in a 24 hour period at 32 degrees ambient. (Of course I guess it depends on whoever is describing it too.)
So the opposite is also true just as Bob indicated....what goes up...must come down.
If your system is relatively new and has worked fine in the past, its condition is suspect. A good servicing may be in order as there is "a ton" (lol) of things to check and adjust to bring it up to par.
If it never has worked adequately maybe sizing is an issue. Lot of good suggestions available and given, need more? Just ask.
This post was edited by missouri massey man at 09:58:26 04/14/13.
