TractorLinks.com
Tool Talk Discussion Forum
Re: Breaker For Lincoln Idealare 300 Welder
Stick welding
04-11-2013 22:07:23
Idealarc 300 or Idealarc 250? I ask because an Idealarc 300 would be either a TM series or a TIG 300 and use more power than a 250? A 250 will go to 300 amps on AC. Does the machine have power factor capacitors? I think a 250 will draw about 72 amps(depending if it has PFC's) but considering the 30% duty cycle at 200 amps, a 50 amp breaker should be OK. I had a Square Wave 255 Lincoln TIG welder that ran fine off a 60 amp breaker. The electrician said the duty cycle of the machine makes a difference in the size of breaker that can be used.
