Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Mis-matched Rear Tires '93 Bonneville
04-11-2013 19:10:59
The best way that works for me is to put the fronts on the rear and the rear on the front... I have seen two many times were moving the tires side to side still leaves a issue... If the issue goes away doing it my way then its one of the original front tires. If I don't see anything wrong with the tires I reverse them one at a time on the rim... Its rare i can not get the pull out if its a tire issue by reversing the tire on the rim...Most tires are blackwall now if I remove one for repair you can bet your arse it gets marked so I don't install it reversed on the rim from the way it was originally installed...... I have sold used tires that pulled bad the fix was to reverse it on the rim. Memory is the only thing I can think of that caused a pull that was not their before if all looks good.
I guess what works for some don't work for others I have never fixed a pull issue by swapping from side to side... I may have improved it but did not know which tire was the bad one... I for sure knew it was a tire issue when it drastically improved it by swapping them to a different axle... Once I knew this it was a matter of playing with the problem tires..
