TractorLinks.com
Tool Talk Discussion Forum
painting house interior
wfw
03-28-2013 13:20:59
Can you use a paint sprayer and compressor to paint the interior of a house? We are trying to get a home and will need to repaint most of the interior. I would like to use m air compressor (this makes it tool related) and a sprayer instead of rollers and brushes.
frank
wfw
03-29-2013 09:49:47
 Re: painting house interior in reply to wfw, 03-28-2013 13:20:59
Thanks for the information, sounds like I would be better off to just roll it. trying to buy a house and will need to paint the rooms. house was built in 1983.
frank
George Marsh
03-29-2013 16:56:23
 Re: painting house interior in reply to wfw, 03-29-2013 09:49:47
Frank, I used a sprayer on new construction, only once. A roller leaves a texture. The wagner paint sticks works best for me. The stick holds about a pint + and the paint is squeezed out the roller. Non stop painting. Makes painting the ceiling easy.
George
Stephen Newell
03-28-2013 20:06:32
A cup sprayer doesn't spray latex paint worth a D. By the time you thin it down where it will spray it will take 4 or 5 coats to cover. Latex paint needs to be under pressure to spray well. Using a compressor you would need a pressure pot to spray. I have a 2 1/2 gal pressure pot attached to a siphon sprayer with 25' of hose. Still if it's just walls and ceiling without a lot of detail to mask I would rather use a airless.
ss55
03-28-2013 19:54:11
If it"s new construction before the woodwork and floors are installed a sprayer is OK if you cover the windows and doorways with plastic.
In an existing house even the professional painters use rollers and trim with brushes. They only put plastic on the floor and tape it to the top of the baseboards, no other taping. If one person is working alone he covers one wall at a time with a roller then trims the edges of that wall with a brush. A two man crew has one person on a roller and one trimming with a brush. They carry a damp rag to wipe off any drips and spatter from the rollers before the wall is dry. They are fast. and do a good job without much taping.
showcrop
03-28-2013 18:07:13
[quote="wfw"](reply to post at 13:20:59 03/28/13) [/quote
A friend gave me a commercial airless sprayer. It is intended for large jobs. It was surplus to his company because they could hire it out for less than they could do it themselves. Any way I used it for the exterior of my shop. I was amazed at how little over spray there was. I loaned it to a friend to do the third floor of his house. He loved it. It is true that you should roll behind it. but it goes very fast because you never go back to the can to reload.
tractor300
03-28-2013 17:52:19
On a new house spray works great, on an older house it is just as quick to roll and a lot less mess. A lot of the pro painter's in my area still roll even after spraying for an evener finish.
TRY IT..John,PA
03-28-2013 17:16:45
I restored quite of few house over the last 50 yrs.
If the house is of vintage, try the procedure "they' used when the house was new.
Probably hand brushing. Later rollers, and of course these days....spray.
If the house is YOURS, I would use the best way for your next project.
Moral to the story.....speedy...spray.
Down side....lots of prep. and cleaning afterwards.
Final time involved about the same, regardless.
John,PA PS: I even ROLL the finishes on vehicles. Sand out, and buff. Same value to the vehicle, afterwards.
Ron Grother
03-28-2013 15:43:21
it takes longer to set up and cover every thing then its worth. it works good on a new house that not trimed out and no door to cover
Wile E
03-28-2013 14:43:02
I have done this several times.
When I was a kid (a long time ago) I worked for a pro-painter. We sprayed the interiors of homes with a 20 gallon compressor and a Binks cup with gun combo. (quart size from what I remember) In a the larger areas we used a 2.5 gallon pressure tank and the gun by itself fed by a 25 foot hose with line. Remember to tape off mask off all stuff you do not want painted.
The best is when it is new construction, you only have to mask off the window with a hammer tacker and visqueen.
Retired Farmer
03-28-2013 14:35:45
I painted the interior of a porch and the inside of my sister's laundromat with an airless sprayer. Cover up everything else you don't want painted because the mist will be all over everything. Wear a mask too.
C.R.
03-28-2013 14:03:34
I picked a roller that has paint in the handle,kind of like a giant syrenge with a roller on the end it worked surprisingly well really speeds up the job you draw paint into it and it has a racketing handle as the roller runs out squeeze the handle and just keep on trucking makes cielings a breeze no ladders needed unless you have really tall cielings
MartyInVa
03-28-2013 16:18:49
 Re: painting house interior in reply to C.R., 03-28-2013 14:03:34
You got it right C.R.
Google Paint Stick. Just cut in with a brush and roll away. Clean up is the hardest part but once you do it, its a breeze. 1 reminder "don"t underestimate how much paint will be needed"
Mike Groom
03-28-2013 13:44:43
I painted my entire house and my son's house with a airless sprayer,just mask the wood work and cover the floors,the clean-up of the sprayer took longer than the actual painting,turned out great!
Dalex
03-28-2013 13:30:09
Sure , I painted a bathroom that way . I just masked off the fixtures and sprayed it in 15 minutes...worked slick !
Ted in NE-OH
03-28-2013 13:28:30
Best not. Over spray on floor, edging is an issue. I would use a roller.
Dalex
03-28-2013 16:47:21
 Re: painting house interior in reply to Ted in NE-OH, 03-28-2013 13:28:30
Like there's no splatter off a roller ?
