Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Gotto love some old machines
60 acre hillside
03-27-2013 18:29:12
The one I had did not have a starting motor but used the generator windings to start. It required two 12v batteries but started easy. It was a good machine.
old
03-27-2013 21:56:38
 Re: Gotto love some old machines in reply to 60 acre hillside, 03-27-2013 18:29:12
This one is old enough it dated back to before an electric start on most any machine. It pulls over hard enough I am likely to be able to pull it more then say 5 or 6 times before I have to take a break
Mike M
03-28-2013 11:59:07
 Re: Gotto love some old machines in reply to old, 03-27-2013 21:56:38
My Army generator dates 1945 and uses the windings to act as a starter.
old
03-28-2013 13:05:03
 Re: Gotto love some old machines in reply to Mike M, 03-28-2013 11:59:07
Ya I have a Koler gen set that is 65KW that is the same way but this old Lincoln has only the arm strong start and that is the only way this one was ever built
Billy NY
03-28-2013 07:28:43
What about an electric motor and belt? It probably would not take much of "Rich's" engineering given the impression I get that you have likely something around the place that might work. Would be slick if you had an idler/spring to tension the belt to grab, and release when it starts. I would imagine that 2 cylinder and pull starting it under full compression is not too easy, and or risky in regards to your back.
Would be great if you figured out something, then at least you could run it once in awhile, so many of those end up sitting and seizing up, my neighbor had a good running lincoln with the wisconsin V4, but let it sit so long without running, ended up in the scrap heap.
I'm a fine one to talk, my miller NT 251 is right outside my garage door, has not run since Sept, 2011 ! Need to clean the carb, and should, clean the carbon out of the heads, adjust the valves, ran well, just loves gasoline though.
old
03-28-2013 08:58:14
 Re: Gotto love some old machines in reply to Billy NY, 03-28-2013 07:28:43
Ya it is all I can do to pull it threw one compression stroke. But it does start real easy and if it is going to start that is all it takes. I would love to rig a kick start to it but that is beyond me. But I might could take an old starter from say a MH and put a pulley in place of the bendex and do that which I have done before on big single cylinder engines
