(quoted from post at 04:32:31 03/27/13) barn find 63 galaxie convert w/352 motor has a cracked block-- will a 352 from a pickup directly bolt in? found one for $150... or I have access to a 302 w/aod tranny. kinda want to keep this all black car original- no real need for speed just a cruiser. thanks in advance
(quoted from post at 06:06:37 03/27/13) Don't the 302/351W and 352/360/390 have totally different transmission bolt pattersn?
on, if you get a chance, I left a question for you on the alternator question a day or two back (Farmall forum, Single wire alt update, March 23).(quoted from post at 13:02:10 03/27/13) 352 from a pickup will fit without problems. You may need to use the car exhaust manifolds, possibly the oil pan and oil pickup tube from the car.
hanks, Jon.(quoted from post at 11:47:12 03/29/13) Sorry I did not get back to that thread, it's on page 10 now.
My answer would be.
"I would say you are correct. The only electrical connection between stator voltage and the "1 wire" regulator is through the diode trio."
