TractorLinks.com
Tool Talk Discussion Forum
Re: Welding steel to cast.
Stephen Newell
03-26-2013 12:16:36
You are right, it is a repulsion induction motor. It came off a WWII era Sears table saw. I used the saw in the early 1970's and something broke on it which I couldn't fix at the time so I salvaged everything I could off the saw and disposed of it. I used the motor on one thing or another over the years but haven't used it in more than 20 years. This week I bought a antique woodworking bandsaw that didn't have a motor so I planned to use this one. I plan to restore the bandsaw so I hate to use a motor with a big hole in it. This is behind the repair. The two cast pieces missing are 2 1/4" straight across the break but if measured around the contour measure 2 1/2". I think I could make the pieces out of 1/4" steel without too much trouble. I was just unsure about welding steel to cast. I believe that end of the motor wouldn't be too much trouble to get off but I will have to double check.
36 coupe
04-05-2013 04:08:34
 Re: Welding steel to cast. in reply to Stephen Newell, 03-26-2013 12:16:36
Using an open motor on a band saw is a poor idea.Sawdust on the brush leads can catch fire.Theres lots of sparking at the brushes during starting.
Stephen Newell
04-05-2013 04:25:23
 Re: Welding steel to cast. in reply to 36 coupe, 04-05-2013 04:08:34
There is not that much dust with the saw it is going to be used on. It is certainly less dust than the saw it came off of. The motor was off an old Sears table saw like this one which the motor was directly under the blade.
