(quoted from post at 00:02:05 12/25/09)
Thanks mmidlam. Nice schematic. The latest is that I was ready to give up and send it off but I don't know where to send the rustbucket to. On Tuesday I was down in Wichita and went to a long time electronics store.
The first guy at the shop in Hutch looked at that C2 cap and said it was a 400 uf with variable 20 to 50 volts dc. With no 400 made, he suggested bumping it up to 470 uf which caused the 10 second delay. The second guy at ICT just glanced at the original cap (buy probably relied upon my 400 uf representation) and said 470 was too high and taking too long to charge and sold me a 330 uf to speed it up.
The second guy also sold me a NTE6408 diac he had in stock which was a 32vdc. He said if it was firing the transformer at all, then the diac and SCR would be good but I bought one anyway. He also had in stock a can scr like mine, a NTE5515, which matched the one I had (PS48) 20 amp & 400v but I didn't buy it for $10. The first guy suggested replacing it with a NTE5516 which was 20 amp & 600v. If I had my druthers, I'd get the new style and place it on a heat sink.
I saw your post today about the C2 and the diagram. Went to radio shack and no 20 uf cap. I stuck the old sprague 400 back in and get what I had before, 27vdc across C2 and 160vdc across C1 which was the same reading as the 470uf cap. It would fire the sprague when I shorted across R4. Next trip to Hutch or ICT I'll get the 20 uf 50vdc cap. I suppose I could experiment with the 330uf or lower cap and go with a lower R4 but probably not worth the trouble or expense.
The first guy identified D1 which you called a protection diode as a NTE580 3amp & 600v general purpose fast recovery/switching silicon diode and sold me one. I see those are used in TV low voltage power supplies and can check ok but under load may not put out enough volts. I assume that it is OK though. Would this D1 diode change it from a half wave rectified circuit to a full wave, I wonder?
The first guy couldn't find anything on the NI-98-C TRA 1374 transformer. Neither could the second guy but he identified it as a flyback transformer and said to try some surplus electronics stores. Googled flyback transformer and learned it is a basic HV transformer used in TVs and monitors with a CRT (picture tube) and fires off of pulsating dc. Also the basic transformer used in things like Tesla coils, a basic high school lab experiment to produce big sparks. Apparently the fence charger is nothing more than a modified tesla coil. Guess I'll look around for an old tv transformer or something similar that will put out 10K to 15K vdc.
The C3 blue output capacitor is marked CRL RF 105-501 500pf 20Kvdc. First guy said they run about a hundred bucks but he thought it just smoothed the output but was mainly to stop RF interference which may not be a problem way out in the barn so not needed. Second guy called it a door knob cap and thought it was needed to smooth and control the output. What's your opinion? Guess when I get it working, I can bypass it and see what happens.
This 909 had a fused plugin with two 1 amp fuses. It was all corroded so I cut it off. Are there any replacements for that style plugin? Neither guy said they could order it
Neither guy could get that style of lightning arrestor but the first guy said they just use a ceramic cap nowadays for that. He showed me one but I didn't get the size. Orange about the size of a dime. (he could have called it a 330uf or something but don't quote me) Both guys told me to get some type of extra surge suppresion plug in strip because the rural electric companies have lots of spikes. Probably my main issue and not lightning. Read that on a website as well.
Your R1 and NE-2 are optional but what would be the value of R1? I guess from its location that this would be a constant on light and not one that pulses with the scr.
Also on my test circuit, there are two resistors (I'd have to remove the plastic tubing to see them) in series going to one side of the test switch and going from there to two 470K resistors to one side of the the lamp. There is a a 470K resistor from one side of the lamp to the other. Then a straight wire going from the other side of the lamp to the other side of the switch. It appears the first side of the lamp is grounded to the case as well.
I still have to call Zareba next week. I see they list International as one of their brands on their literature now. Maybe they can locate a transformer and output cap. Main reason is that I bought one of their 9.9kv digital testers and it keeps shocking me through the case. Gotta be defective somewhere. Gonna have to get rubber gloves to use it.
Thanks for everything so far. Guess I'll keep plugging away here.
I typed up the following reply from what showed and the "Classic" Board, and then decided to check "Modern" and I see it appears your problem as been solved ("Brainic" you talked to reversed voltage can capacitance ratings of the C2 capacitor).
So, just to be a nuisance, I'll post the already-typed reply here:
A few random thoughts...
That fencer circuit is a simple "relaxation oscillator" and with the power supply parts (R2 and R3, the rectifier diode, D1 and the capacitor C1 functioning the triac should repeatedly "fire", even if the pulse transformer is "bad".
Did you say the triac WAS being "fired" at 10 second intervals with the 470 uf capacitor?
If so, when it fires, is there any output from the pulse transformer?
You mention 27 Volts across C1. The one diac (trigger diode) you mention is rated at 32 Volts.
A diac that triggers at 32 Volts ain't gonna trigger at 27 Volts.
Have you had C2 tested for leakage? That's PROBABLY why the R4 resistor can't charge it to the voltage needed to trigger the Diac.
Your "Brainiac" guessed it was a "400 uf with variable 20 to 50 Volts DC.
Well, guess what, 'lytics AIN'T rated that way. It's a 20 to 50 uf, 400 VOLT capacitor, in line with the 20 uf unit in mmidlam's schematic.
DigiKey will sell you a 20 uf capacitor rated at either 50 Volts (schematic) or 400 Volts (rating of old unit).
Toss a 20 uf 'lytic in there and tweak the value of R$ 'til you get the desired one pulse per second, THEN see what's coming out of the pulse transformer.
If needed, DigiKey will sell you a 500pf 20Kv capacitor for about $56.00. There's a guy on ebay selling 10 (good?) used ones for $19.99.
http://en.wikipedia.org/wiki/Relaxation_oscillator
