Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: 7.3L Diesel Rear Main Seal
ASEguy
03-25-2013 05:29:37
Since he's pulled the tranny, I'm sure he's verified it's still the rear main seal. I would check the crankshaft sealing surface. Clean it up with crocus cloth or a 600 grit sandpaper. Get it clean with with starting fluid or brake cleaner. Inspect for any scoring. Check crank endplay. Usually it's under .015. If he's installing a teflon seal MAKE absolutely certain no oil is on the sealing surface before installation. Otherwise lube it with clean engine oil. Some engines REQUIRE rear main seal installation tools. Find out from Ford. In my experience excessive crankcase pressure caused more than one seal to leak. It didn't just cause the rear main to leak. Hope this helps. Gerard
