TractorLinks.com
Tool Talk Discussion Forum
Re: Solenoid switch
GUIDO
03-24-2013 07:03:46
Hello George March,
Thanks for the explaination. Saved me the time to do it. I have taken the solenoid apart. It had a bad ground and was rusty. I soldered A wire to the negative side of the solenoid and wrap it around the spring. Had to drill out the rivets to take it apart, and i used screws to put it back togather. HEY! its not my first rodeo! No other safety devices in this case.
HO! by the way.................. it works.
Guido.
JRSutton
03-25-2013 09:24:15
 Re: Solenoid switch in reply to GUIDO, 03-24-2013 07:03:46
One thing to keep in mind - sometimes they burn out - and sometimes they get stuck - but often for the same reason -
yeah some do get old and die - but often bad connections (or a bad starter) force the starting circuit to draw extra current.
the solenoid/relay parts - just like anything else - heat up more when more current is pulled through them.
That can lead to failure or relay sticking.
so - fixing or replacing a relay is sometimes only a temporary fix...
Always good to check the whole circuit - worn starter motor - bad ground connections - frayed battery cables - bad batter connections...
George Marsh
03-24-2013 14:59:41
Guido,
Glad it worked for you.
There are many places on line that sell mower parts real cheap. I just purchased a new honda carb $48, rebuild kit $9, shipping, handling $12 for my 4 stroke husky weedeater. Most new carbs run twice that amount. Just got it yesterday, looks just like the old carb. Hope it works.
George
dr sportster
03-24-2013 11:04:54
Once I saw the pictures of it taken apart I knew you were going to fix it yourself. I always drill out rivets of stuff like that . File and spray and see what you can get away with. Ha ha good save.
GUIDO
03-24-2013 12:22:18
 Re: Solenoid switch in reply to dr sportster, 03-24-2013 11:04:54
Hello dr sportster,
o Thanks!once I knew the coil was good, I took time to clean it. Works just fine.
I know it is not that much to buy one. I like to be green, heck I've been green way before it became a cool thing to do.
Have a good day..................Guido
