Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: the answer
Chris(WA)
03-24-2013 04:17:46
If the flaw was that you hit it with your leg and threw it out of alignment and then went and welded it up that way, how is it the customers fault in how he speced the trailer?? That is what you iluded to in your first post...
jon f mn
03-24-2013 05:12:10
 Re: the answer in reply to Chris(WA), 03-24-2013 04:17:46
It was rejected for totally unrelated reasons. When it was done the first time it had the lighter axles on the other trailer and only a 2' beavertail. The guy couldn't use it because it was too high and the tail was too short and the ramps were to short so the bends were to sharp. He sold and serviced lawnmowers and riders wouldn't go over the bends. When I redid it I put on heavier axles. To do that I added a subframe to raise the trailer for tire clearance for the taller tires. I also extended the beavertail to 5' to get it a bit lower and make it more usefull.
Chris(WA)
03-24-2013 10:38:46
 Re: the answer in reply to jon f mn, 03-24-2013 05:12:10
Ah HA! Now it makes sense. Thanks for clarifying it Jon. BTW- What did you use for the leveling deck on the beavertail of the second trailer. Looks like a good idea.
jon f mn
03-24-2013 11:11:20
 Re: the answer in reply to Chris(WA), 03-24-2013 10:38:46
I do that by continuing the crossmembers down the tail just like the deck. Then make a frame out of 1 1/4 or 1 1/2 square tube and weld a diamond plate to it. The top hinge is just a 1" shaft inside the top tube for a few inches on each side. The bottom is supported when up with a frame made out of the same tube that just tips forward underneath when its down. A couple of tabs on the support frame to keep it under the top and that's it. When up it's only for light stuff like hay and lumber and such. If you want to haul something heavy the deck needs to be down, that way there is no need for spring lifts and such.
jon f mn
03-24-2013 05:05:02
No, you missunderstood. The customer never knew that it was flawed when he rejected it. That was a totaly separate issue and just and interesting history I thought.
