TractorLinks.com
Tool Talk Discussion Forum
Re: Solenoid switch
Gambles
03-23-2013 18:16:50
Was taught 30+ years ago in auto mechanics school that it is a solenoid SWITCH. Even on the old Ford starters, the solenoid is technically on the starter. I guess it really doesn't matter though. If you go to a parts store and ask for a solenoid, you will get your solenoid switch handed to you by the parts man.
JMOR
03-23-2013 19:07:13
 Re: Solenoid switch in reply to Gambles, 03-23-2013 18:16:50
"doesn't matter" is correct answer. My original Model T Ford parts manual says "motor", whereas most in current times use 'motor' to mean a shaft output electrically powered device and the Model T power plant , an "engine". But all but the annal (sp) know what it meant. Solenoid is a magnetic device that moves a core or plunger. Now what that movement does is up to the designer. It might be a door latch, door lock, trunk lid latch, a copper washer pulled against tow copper bolt heads, or move a bendix into a flywheel, or holy moley, even both as in a 60's GM starter (switch & bendix mover all with one solenoid!!
