TractorLinks.com
Tool Talk Discussion Forum
Re: I made a dump trailer (pics)
cd1
03-21-2013 11:34:52
For only 6200 lbs in the bed I think you will be fine. The only thing I personally would have done different is a larger gusset at the front of the main frame into the vertical tubes but I can see why you didn't as your bed would have hit them which you could have used flat iron to basically truss out around the corner but in all reality you will probably be fine. I think a lot of people on here would be amazed at how light most commercial trailers are. There is a balance between weight and load capacity, if you over build it like crazy that just takes away from your cargo capacity for no reason.
