TractorLinks.com
Tool Talk Discussion Forum
Re: Peening welds
IrvIA
03-20-2013 20:19:14
Do you weld it across the crack as was suggested to me? I guess there's more than one way of doing things.
Irv
el6147
03-21-2013 09:34:42
 Re: Peening welds in reply to IrvIA, 03-20-2013 20:19:14
I would guess everyone has their own way or technique , often one learns by doing and I don't believe there is one set of rules when it comes to cast . Often I v-groove , small holes and each end if it is a crack so the crack does't continue , single pass in the groove making sure all flux is cleaned out before your next short weld is started and I do what I would refer to as a side to side Z pattern on the cover pass or when the opening begins to widen as you stack weld on top of weld as your filling the V-groove and the absolute perfect way to weld cast is oxy-acetylene with a cast iron filler rod with cast flux and that one can only learn by doing .
Stick welding
03-21-2013 22:16:39
 Re: Peening welds in reply to el6147, 03-21-2013 09:34:42
Spray welding is also one of the best methods to repair cast as is brazing. Stick welding is just fine for some cast iron repairs.
