Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Wiring info wanted
Indiana Ken
03-19-2013 07:56:15
Quoting Removed, click Modern View to see"
I am a little confused however, it sounds like you use the three way switch to open and close the garage door. The short life of the light could be caused by vibration from the garage door opener - standard incandescent bulbs are very sensitive to vibration. A rough service bulb would last much longer in this application, if vibration is the problem. CFL and LED bulbs would also be an option. CFL and LEB bulbs use so little power it does not manner if they burn a few extra hours per day - you would likely never recover the cost for an electrican to separate the socket from the outlet.
As to disabling the light, the hardware stores used to sell an adaptor with a pull chain switch. You unscrew the bulb from the light socket, screw it into the adaptor then screw the adaptor/with bulb into the light socket. To disable the light you switch it off with the pull chain switch.
03-19-2013 12:49:58
 Re: Wiring info wanted in reply to Indiana Ken, 03-19-2013 07:56:15
No, don't use 3 way switch to open and close door. I mentioned that just to show there was a light right next to the plug. Light and plug aren't connected in any way. Short bulb life not because of vibration. I hardly ever close the garage door. Mostly only when going to be gone overnight. Told wife we shouldn't close it then because that was a sign we are gone LOL. The adapter with a pull string sounds good. I know exactly what you speak of, just didn't think about that.
