Goodafternoon, everyone!!
So, here's my latest repair... Its a Cast Iron bench vise I'm fixing up for a buddy of mine...
When the thing showed up, the front jaw was cleanly broken from the slide, and I knew it had seen some better days...
So, a quick spark test determined it was probably gray cast iron, possibly white cast, but either way I knew it was, ideally, a job for Nickel Electrodes.
I'd used 7018 with success before, but since this wasn't my vise I didn't want to take a chance on it. I spent $30 on a pack of 10 Nickel-99 Electrodes from Tractor Supply, and after realizing they were only 12" long instead of the usual 14, I got to work.
I quickly discovered that the instructions were useless and it took almost twice the "recommended" amperage to put down a half decent weld, but got setup to run them at 95 amps on A/C...
After lighting up the rosebud and preheating the daylights out of the casting, I started welding, peening, welding some more and hopeing for the best...
I then buried the part in sand, and HOURS (literally) later it was cool enough to touch, and then I torture-tested the finished repair. I'm very happy with how this turned out, I got to run some nickel electrodes, and had another successful cast iron repair...
Quick question: Does anyone know how those cheaper "Normacast" electrodes compare to the nickel rods? I see they're quite a bit cheaper and I want to try them out, too. Just wondering if anyone has any experience with them...
Anyway, I just thought I'd stop in and share this video with y'all... It was really fun to make, and I hope you guys enjoy it
Have a great week, everyone!!
video1
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/qeJQEDTpTaE?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/qeJQEDTpTaE?version=3&hl=en_US" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
video1
