2007 Focus question
JOB
My daughters 2007 Focus over heated last night. Looking to find the problem I see a nipple coming out the side of the right side radiator tank. About six inches above the lower radiator hose connection. But 90 degrees from the direction of the radiator hose. I can not see any hose lying around that needs a home. Does this nipple just get a clamp on cap. Or should there be a hose somewhere? Any Ford mechanics out there?
Put some water in it and look around. Also what sprint6 said. We've had 3 Foci at one time. (girls) Have had a cracked thermostat housing also, which is at the engine where hose goes.
I am hearing now that the nipple is where a vent
hose connects I can not see a hose hanging loose at
all. The nipple is where all the water was lost.
Daughter heard a loud pop when it let loose.
