TractorLinks.com
Tool Talk Discussion Forum
Re: Hobart Welder
Stick welding
03-17-2013 10:51:43
If it says it runs might mean that everything works. Hobart made very good welders. The Alaska pipeline was welded with Hobart welders using automatic CRC MIG equipment. This sounds like the same model of welder. If it is, it is a constant current, constant voltage machine which means you can run stick or a wire feeder off of it. The model might be DCC-350-P! These would be equivalent to the Miller Trailblazer 55, that Puddles used to own and has pictures of, or a lincoln SAM 400. The welder would have cost around $14,000 or more when it was new and weigh around a ton. I bet you could get it for under $2500 which would be a steal! The engine alone is worth that.
