TractorLinks.com
Tool Talk Discussion Forum
Re: Old Gasoline Soldering Iron
dr sportster
03-16-2013 09:35:54
I don't think gas goes into that ,but it sits on top of the gas torch in a holding fork to be heated up. A guy in the next town at the feed and grain store has quite a collection of these on display .Although the name is telling me I'm probably wrong and this one is self contained.Is there a filler cap on it ?
Rollie NE PA
03-16-2013 10:18:07
 Re: Old Gasoline Soldering Iron in reply to dr sportster, 03-16-2013 09:35:54
I just dug out the directions.
To charge, unscrew and take off the fiber handle.
Fill the tube with gasoline.
Screw on the filling cap tightly and replace the fiber handle.
Stand iron on end and fill the priming cup full of denatured alcohol or gasoline and light. When it is burned out, immediately open valve and touch lighted match to large holes under copper point. The vapor in the tube will ignight causing a strong hissing noise which indicates the iron is burning well.
WOW! Sounds like a finger burner.
Mike (WA)
03-16-2013 10:45:03
 Re: Old Gasoline Soldering Iron in reply to Rollie NE PA, 03-16-2013 10:18:07
After seeing the directions, I'll stand by my earlier post.
When everything is working right, and you do it right, they're probably fine. But what if you let the primer cup and tube get too cool, while you try to get your old Zippo lighter to work, and you get liquid gas instead of vapor out the tube? Bigggggg problem. . .
Stick welding
03-16-2013 11:27:30
 Re: Old Gasoline Soldering Iron in reply to Mike (WA), 03-16-2013 10:45:03
Petrogen gasoline cutting torches claim they are safe because if they get a leak it will be liquid gasoline and not vapor. The vapor burns, not the liquid.
