Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Furnace pilot light won't stay lit
missouri massey man
03-12-2013 04:17:30
The thermocouple works by having the junction of two dissimilar metals heated. When heated they generate that milli voltage. The safety coil in the redundant gas valve will be held in only when the milli voltage generated by the thermocouple matches it. You are bypassing that safety coil by depressing the button long enough for the milli volts to take your place. Typically what you are describing is one of three things: 1) Bad thermocouple 2) Insufficient heat on the thermocouple end...too small of flame or flame is so high it is actually bypassing where it needs to be 3) Defective holding coil in the safety circuit.
Why possibly a bad thermocouple? We are finding poor quality of products flooding the US market in virtually everything, why not thermocouples too... Usually if the junction of the two dissimilar metals (swelled up end) of the thermocouple is intact it will generate sufficient milli voltage, but that is no longer true with the lower quality of materials.
Though a slim possibility, the same applies to the redundant gas valves holding coil. If bad, the gas valve needs to be replaced. The easiest way to check it is with another new thermocouple. This will ring true ONLY if the pilot is adjusted properly and coming in contact with the thermocouple properly.
Make sure you have a strong pilot flame encompassing a minimun of 1/2 to 3/4" of the end of the thermocouple. There should be a nice inner core of blue with a different softer and larger outer ring of blue with NO yellow. Yellow or white in the flame will indicate imminent carbon build up. A tad of orange is all right as usually that will be superficial rust particulate sucking into the flame as you are or have been disturbing the area surrounding the pilot with all your work. That will go away mostly. Please keep us informed on what you do and what you find.
Dusty MI
03-12-2013 04:29:14
 Re: Furnace pilot light won't stay lit in reply to missouri massey man, 03-12-2013 04:17:30
I've checked thermocouples with a DC volt meter and a propane torch.
Dusty
missouri massey man
03-12-2013 05:00:51
 Re: Furnace pilot light won't stay lit in reply to Dusty MI, 03-12-2013 04:29:14
Yeah, I too have a few tricks up my sleeve and have done the same thing...I used to carry an old "Baso" switch to check the thermocouples with. Just left the pilot assembly in the furnace, unscrew the end into the gas valve and screw into the Baso and relight the pilot while holding down the redundant valve to maintain pilot gas flow. After 10 maybe 15 seconds, depress the Baso switch and if it holds in then the thermocouple was generating adequately. I have been doing commercial and industrial for the last 25 years so this old school technology (if you can call it that) is slowly going by the wayside. I probably haven't touched a standing pilot in a decade.
I was thinking he probably doesn't have a dvom and was going for the basic description of the pilot circuit sequence so the repair can be made with nothing special.
He's gotten a lot of good suggestions so far and I am confident he will figure it out.
