TractorLinks.com
Tool Talk Discussion Forum
Re: MIG Welding Aluminum?
jon f mn
03-10-2013 07:45:58
If your going to buy a welder for aluminum be careful what you buy. I started with a miler 200 which worked great, but then the salesman talked me into upgrading. I've had a miller 250, 250x, 251, and a couple others and eventually went to the vintage mentioned below. The ones with the computer controls and electronics will build up a static charge when you let off the trigger. It doesn't hurt to much on steel but it will stick the wire to the tip on aluminum. They actually weld ok once the weld is started but you will use 10 times more tips that with an old style welder with machanical contactors. For me the electronic welders would use about 1 tip per 1 lb roll of wire, the machanicals will run 10 or more rolls through a tip.
