Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: belt dressing
dr sportster
03-09-2013 08:58:22
There are four sizes of SAE belts. There are three angles of pulley.34 -36 and 38 degrees. If you want to clean up the pulley on a lathe you would set the angle to half the degrees . Example 36 degrees set to 18 degrees to clean up groove and check that it does not bottom out [as in the pics below]. If so then a cut across the bottom is needed. The belt will ride lower but now that the proper angle is recut will not slip.
