TractorLinks.com
Tool Talk Discussion Forum
Re: Shop Floor Heat
George Marsh
03-06-2013 10:13:21
jaden,
Bet once you get the concrete warm, it will stay warm for a while. I think the specific heat for concrete is about 0.5. Water is 1.0. What this means it is it takes the same energy to heat 2 pounds of concrete as it takes to heat 1 pound of water.
Your slow response is because you have tons of concrete, thermal mass, to warm up.
If it require 24 hours to recover, water heater not shutting off, it would cost me about $15.
Could see the advantage of having dry floors.
I was working in my 24x24 garage today, not shop, which is attached to my house. I can heat it with a 1500 watt baseboard heater. However, I haven't had the heater on in years. The garage temp was 45. Last night it was about 20. My garage has over R20 walls, R50 ceiling, Anderson windows, insulated doors. Leave windows cracked open a little to keep it dryed out. I think the reason my garage stays warm is because it is south facing, brick on the outside, some heat comes through the insulated wall from house and the main reason is my 6 inch concrete floor is resting on 8 inches of pea gravel. The gravel acts as an insulator.
Hope your heating works well for you. Like you said, you could heat the water with anything. May find out propane is cheaper.
George
sflem849
03-06-2013 11:55:36
 Re: Shop Floor Heat in reply to George Marsh, 03-06-2013 10:13:21
That is what most people do. An electric water heater is the least cost effective method.
Go to AgTalk for WAY more info on what people are doing with in floor heat. It is a good idea if you are going to be in a shop everyday. If you are only there on nights or weekends radiant tubes seem much better.
George Marsh
03-06-2013 12:20:29
 Re: Shop Floor Heat in reply to sflem849, 03-06-2013 11:55:36
sflem849,
Decided to crunch some numbers. My 30x40 pole barn has a 6 inch floor. Using my floor, it will take 444,444 BTU's to change concrete just 10 degrees. If I used a 5500 watt electric water heater, it would take 23.7 hours to do the job. Not factoring in any heat losses. SOOOOOO, it will cost me $15 to change my floor temp 10 degrees.
If anyone wants to check my calculations:
specific heat for concrete is 0.5
1 yard of concrete is 4000 pounds.
these numbers may not be exact, but close. I was trusting my old memory.
George
sflem849
03-07-2013 04:42:00
 Re: Shop Floor Heat in reply to George Marsh, 03-06-2013 12:20:29
So wouldn't this be true for propane? There are 91,300 btus in a gallon of propane. Propane is around $3/gal right now. So it would cost $14.60 to heat the same floor with propane. About the same.
Don't you need to account for efficiencies somewhere in the calculations?
GordoSD
03-06-2013 15:49:21
How many KWH to MAINTAIN it at say55 degrees?
George Marsh
03-06-2013 19:39:55
 Re: Shop Floor Heat in reply to GordoSD, 03-06-2013 15:49:21
GordoSD,
Heat loss is calculated by knowing the R rating of walls, ceiling, windows, doors, loss through ground, not to mention air infiltration. You also have to know the delta temp between inside and outside temps. Windows are rated in U ratings which you convert to R. R = 1/U Oh, you also need to know the surface area of each part of the building too, doors, windows, walls, ceiling, floor.
Give me that, the rest is very simple.
It's very cheap to heat just air.
George
