TractorLinks.com
Tool Talk Discussion Forum
Re: pole barn insulation
MSD
03-04-2013 17:57:46
If your using fiberglass blown in it doesn't weigh much and should work. Cellulose is a little heavier but if you have an engineered truss it should be able to handle the extra weight if it was designed for a hanging ceiling. Foam on the roof panels is the best way to go. No drips and no heat buildup in the summer.
tractor300
03-05-2013 11:18:29
 Re: pole barn insulation in reply to MSD, 03-04-2013 17:57:46
I used the 5/8" hard foam before I put the tin on on a 48x36 shop. A large ceiling fan will help distribute the heat. Also put on the sidewalls. Worked great without all the hassle of a ceiling and insulation. I never used over 250 gal. of fuel any winter, located in central Ill. Didn't keep it over heated, just comfortable to work. Would do the same again. The only drawback is keep the doors shut and the birds out, they love the foam. It is actually worth more in the summer as it keeps it about 20 deg. cooler than outside.
