Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Rosebud tip
JOB
03-04-2013 04:33:17
Puddles, The first video is the procedure that I use. That is procedure that Smith recommended back in the early 70's for O/A . Somewhere along the way the oxygen valve was recommended to be shut off first with acetylene. I asked why, and the reply was everything is a fuel, even the copper tip. So if the copper tip is hot enough and you shut off the acetylene first the oxygen can cause the tip to burn and start a fire. I DO NOT AGREE with what I just repeated. My experience with O/A is if the cutting tip is too hot it will pop and go out it will not stay lit. Never had a problem with a heating/welding tip. A couple of times in a paint booth I was cutting out return saddles for the conveyor chain, the tip got so hot it would not stay lit so I cooled the tip by putting the torch head in the water of the flood sheets. All the way up to within 1/8 inch of the flame. The torch was not adjusted improperly, that conveyor is covered with paint over spray so you have the torch in a fire as you are cutting. And yes the fire does get bigger and is put out with water before it gets too big to work in.
The second video you posted is for propane. I have zero propane experience so do not know if there is a special procedure, different from O/A for light up and shut down. I did learn something from the Smith video though.
Here is a picture of one of the paint booths I have worked in. One of the sprayers in the manual section. Most of the booth is automated.
I could not get the picture to post. I need another lesson.
Puddles
03-04-2013 08:26:46
 Re: Rosebud tip in reply to JOB, 03-04-2013 04:33:17
In welding school I was taught to turn the oxygen off first. And I think every thing I've read and seen to date says to turn the oxygen off first. But I've been doing this for so long now I have my way of doing things, and it has worked great all these years, so very little I do is up for discussion to change.
What I like about Jody's video, (first one) is how he explains about backing the adjustment valve off after each use, and stand to the side when you turn the bottles on. But I had to laugh when I seen he turns the fuel off first. I'll bet I've been around 10,000 weldors in my life, I can't remember a one who turned the oxygen off first.
JOB
03-04-2013 13:18:43
 Re: Rosebud tip in reply to Puddles, 03-04-2013 08:26:46
Puddles, do you have a typo in your second paragraph last sentence. Or am I not understanding something?
Puddles
03-04-2013 13:28:58
 Re: Rosebud tip in reply to JOB, 03-04-2013 13:18:43
I don't think so, but you'll have to spell it out for me. What do you mean? :?
JOB
03-04-2013 17:08:33
 Re: Rosebud tip in reply to Puddles, 03-04-2013 13:28:58
If I understood your reply you turn off the oxygen first when shutting down your torch. The 10,000 others weldors you have been around turn off the acetylene first. I assumed the 10,000 other weldors may have turned off their torches the same way you do?????
Puddles
03-04-2013 17:13:15
 Re: Rosebud tip in reply to JOB, 03-04-2013 17:08:33
No, I always turn the fuel off first. And everyone I've been around turns the fuel off first as well.
Stick welding
03-04-2013 15:55:00
I think he means you meant to say you have never seen anyone shut the oxygen off first.
JOB
03-04-2013 05:28:46
I will try my picture again
