| Tool Talk Discussion Forum |
Topic: Re: Rosebud tip
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Stick welding
03-03-2013 13:01:22
96.53.210.246
A lot of times with a rosebud you use higher oxygen pressure to help cool the tip but since you're not melting the steel, you don't need to equalize the rosebud. As far as flashback arrestors, I've read(Esab I think) where it says to not use check valves when using a rosebud because they restrict the flow of gas to the tip. Flashback arrestors also have a check valve. In school and on the job never had anyone say to shut the oxygen off first. |
| JOB
03-03-2013 17:15:12
173.84.196.47
Re: Rosebud tip in reply to Stick welding, 03-03-2013 13:01:22
| Mr. Stick, Argue with the people at Smith. Maybe you can teach them something. |
| Stick welding
03-03-2013 21:58:19
96.53.210.246
Re: Rosebud tip in reply to JOB, 03-03-2013 17:15:12
| | We had Smith equipment at the trade school I went to and all the Smith safety posters as well. When you have an acetylene manifold and students with no experience, you don't take safety for granted. Teacher was very experienced and even in technical school with a couple dozen experienced welders, none of them taught us to shut the acetylene off last. I've never read a manual for any torch that tells you how to properly equalize a tip for welding either. They all tell you to set the gauges the same yet the most accurate way doesn't rely on the gauges at all. I guess they don't want to tell you their gauges aren't accurate. |
| Puddles
03-03-2013 17:34:58
24.113.77.208
| JOB
03-04-2013 04:33:17
74.36.133.31
Re: Rosebud tip in reply to Puddles, 03-03-2013 17:34:58
| Puddles, The first video is the procedure that I use. That is procedure that Smith recommended back in the early 70's for O/A . Somewhere along the way the oxygen valve was recommended to be shut off first with acetylene. I asked why, and the reply was everything is a fuel, even the copper tip. So if the copper tip is hot enough and you shut off the acetylene first the oxygen can cause the tip to burn and start a fire. I DO NOT AGREE with what I just repeated. My experience with O/A is if the cutting tip is too hot it will pop and go out it will not stay lit. Never had a problem with a heating/welding tip. A couple of times in a paint booth I was cutting out return saddles for the conveyor chain, the tip got so hot it would not stay lit so I cooled the tip by putting the torch head in the water of the flood sheets. All the way up to within 1/8 inch of the flame. The torch was not adjusted improperly, that conveyor is covered with paint over spray so you have the torch in a fire as you are cutting. And yes the fire does get bigger and is put out with water before it gets too big to work in.The second video you posted is for propane. I have zero propane experience so do not know if there is a special procedure, different from O/A for light up and shut down. I did learn something from the Smith video though. Here is a picture of one of the paint booths I have worked in. One of the sprayers in the manual section. Most of the booth is automated. I could not get the picture to post. I need another lesson. |
| Puddles
03-04-2013 08:26:46
24.113.77.208
Re: Rosebud tip in reply to JOB, 03-04-2013 04:33:17
| In welding school I was taught to turn the oxygen off first. And I think every thing I've read and seen to date says to turn the oxygen off first. But I've been doing this for so long now I have my way of doing things, and it has worked great all these years, so very little I do is up for discussion to change.
What I like about Jody's video, (first one) is how he explains about backing the adjustment valve off after each use, and stand to the side when you turn the bottles on. But I had to laugh when I seen he turns the fuel off first. I'll bet I've been around 10,000 weldors in my life, I can't remember a one who turned the oxygen off first. |
| JOB
03-04-2013 13:18:43
74.36.133.31
Re: Rosebud tip in reply to Puddles, 03-04-2013 08:26:46
| Puddles, do you have a typo in your second paragraph last sentence. Or am I not understanding something? |
| Puddles
03-04-2013 13:28:58
24.113.77.208
Re: Rosebud tip in reply to JOB, 03-04-2013 13:18:43
| I don't think so, but you'll have to spell it out for me. What do you mean? :? |
| JOB
03-04-2013 17:08:33
74.36.133.31
Re: Rosebud tip in reply to Puddles, 03-04-2013 13:28:58
| If I understood your reply you turn off the oxygen first when shutting down your torch. The 10,000 others weldors you have been around turn off the acetylene first. I assumed the 10,000 other weldors may have turned off their torches the same way you do????? |
| Puddles
03-04-2013 17:13:15
24.113.77.208
Re: Rosebud tip in reply to JOB, 03-04-2013 17:08:33
| No, I always turn the fuel off first. And everyone I've been around turns the fuel off first as well. |
| Stick welding
03-04-2013 15:55:00
198.53.83.89
| I think he means you meant to say you have never seen anyone shut the oxygen off first. |
| JOB
03-04-2013 05:28:46
74.36.133.31
| I will try my picture again |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
