| Tool Talk Discussion Forum |
Topic: Re: Explain this crack
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| RodInNS
03-02-2013 07:10:40
216.118.158.123
I kinda tend to agree with you that it's too hot for brazing. Generally I wouldn't... but in this case you can see the discoloration in the bend that says the bend was a lot hotter than the rest of the pipe... which is quite natural. I would say it probably takes on a dull red that would be visible at night... which is mabey not hot enough to make brass run but it's certainly hot enough to make it soft and weak.Rod |
| Stick welding
03-02-2013 09:56:46
96.53.210.246
Re: Explain this crack in reply to RodInNS, 03-02-2013 07:10:40
| If I remember right, brazing is good up to about 800 deg's. Directly out of the exhaust port and a bend too boot, would get that pipe pretty darn hot when that engine is working. I think exhaust temps can reach 1200 and even 1600 deg's. Some exhaust throws flames and does gets glowing red when you see it at night. The discoloration could be from rain on the hot exhaust pipe. The pipe could just be worn out too. I've seen a cast iron manifold worn out from getting so hot. It was on an IH tandem with a 549 V-8 gas engine. |
| RodInNS
03-02-2013 10:26:54
216.118.158.123
Re: Explain this crack in reply to Stick welding, 03-02-2013 09:56:46
| EGT on that little thing shouldn't run much above 900 in the pipe. 900-1000 is fairly common. More discoloration in the bend is fairly common because the blast is directed at it and focused on that spot. It was always a common thing to see Ford's that were turned up... blow the top bend out of their mufflers. I've brazed diesel exhaust pipes before. Generally, if the high temp paint on the pipe hasn't been burned off the brass will be fine... but in this case... I'd say the pipe is already thin from the inside. It probably wasn't much more than 16 ga anyhow. It's just thankless trying to fix that. One thing to play with it; quite another to charge someone money for it.Rod |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
