TractorLinks.com
Tool Talk Discussion Forum
Re: Bit sharpener
JD Seller
03-01-2013 22:23:39
I have a drill Doctor and I have had good luck with it. I use it all of the time. I know many say that the Drill Doc does not work. I found you need to learn how to set it up correctly and it will work fine. It is easier to setup on larger bits. So start with a 1/2 or similar bit and you can feel how to set it much easier than on a smaller bit. Once you get used to setting it the smaller bits are easy to do too. I have found it does not work very well on bits under 1/8.
