| Tool Talk Discussion Forum |
Topic: Bit sharpener
[Return to Forum]
| Author |
[Modern View]
| Notjustair
03-01-2013 17:27:49
174.238.70.124
Anyone have a drill bit sharpener? I had always thought that when they got too bad they were done for. Now I have so many dull sets. I need something that takes care of the angle/pitch for me. Anyone got a recommendation? |
[Reply] [No Email] | |
| Diydave
03-03-2013 02:59:23
96.244.165.121
Re: Bit sharpener in reply to Notjustair, 03-01-2013 17:27:49
| A couple years ago, I sharpened about 150-200 drill bits, with my drill Dr, good results, I painted the tips with a felt tipped paint pen, to keep the rust off. |
| Dusty MI
03-03-2013 04:52:16
97.106.7.126
Re: Bit sharpener in reply to Diydave, 03-03-2013 02:59:23
| I marked one of the two 180* marks so I know that I've turned the chuck an even number of times.
Dusty |
| Don-Wi
03-02-2013 19:36:37
75.207.57.40
| I was just stating a fact, I have access to a Darex, which is better than the drill dr. If it's made by Darex, then it's gonna still get the job done. It's just obviously much cheaper for the homeowner.
Every drill I set up at work, be it for 1 hole or 100 or 1000 holes, gets a quick pass on the sharpener. Dad got a used drill doctor somewhere and I've used it (worked ok), but it's always not where I am so I go in the shop and use the bench grinder. If a whole bunch are dull, I just bring them all in and give them a quick once over. The added benfit is I can split the points too.
Here's the one we have, and we've got the countersink attatchment to go with it. It's only $3600....
http://www.darex.com/index.php?option=com_virtuemart&Itemid=4
Donovan from Wisconsin |
| Jim in MN
03-04-2013 11:37:31
166.152.226.108
Re: Bit sharpener in reply to Don-Wi, 03-02-2013 19:36:37
| I bought a Darex SP-2500 several years ago from a shop that was closing down. Even used it wasn't cheap, but it has paid for itself many times over. |
| Wile E
03-02-2013 16:47:21
66.188.56.202
| Belt sander, works perfectly---As long as you know what you are doing. Small, big. |
| 44 massey
03-02-2013 15:15:38
74.46.121.185
| I use a drill doctor also and it works for me!!! I agree under 1/8 is hard to do!! |
| 60 acre hillside
03-02-2013 01:35:56
67.142.170.27
| Do you have a neighbor who is a retired machinist? He may be delighted to tour your shop. |
| JMS./MN
03-02-2013 18:51:57
209.237.125.241
Re: Bit sharpener in reply to 60 acre hillside, 03-02-2013 01:35:56
| Perfect response! Older machinist in my first job- I was just out of Army, going to college, needed some $$$ beyond GI Bill if I was going to have a life...ie, chase girls.....'Frugal' machinist showed me how to sharpen drill bits with a simple gauge of stamped metal, with the correct angle degree and markings. Use it to this day. College Ag Engineering course, we made another, but not as accurate. Drill Doctors are fine for those that need them, but if you have a handy machinist to teach you how to use a simple gauge.......the older gentleman can teach us sooooo much! |
| JD Seller
03-01-2013 22:23:39
208.126.196.144
| I have a drill Doctor and I have had good luck with it. I use it all of the time. I know many say that the Drill Doc does not work. I found you need to learn how to set it up correctly and it will work fine. It is easier to setup on larger bits. So start with a 1/2 or similar bit and you can feel how to set it much easier than on a smaller bit. Once you get used to setting it the smaller bits are easy to do too. I have found it does not work very well on bits under 1/8. |
| JMS/.MN
03-01-2013 22:04:52
209.237.125.241
| I just use a drill sharpening guide that I bought for about $1.89 at Sears, during my first machine shop job, 1967. |
| 2x4
03-01-2013 21:38:37
206.35.11.174
| I've got an old Black & Decker that gets me by. Prolly nothing a pro would have but useful occasionally. |
| Don-Wi
03-01-2013 18:13:55
75.207.122.174
| I bring ours to work, where we've got a Darex. Tons better than the drill doctor, but tons more money too. I can do just about all of our drills, which is 2 drill indexes, 1 of them containing fractional, number, and lettered drills, in less than an hour. Probably closer to a 1/2 hour.
I can also sharpen them free hand and ussually do when the tip gets dull at the farm, but the Darex is just lots quicker, more accurate, and just does a better job.
I need to bring them in again, now that I think of it...
| sflem849
03-02-2013 16:27:50
69.197.84.39
Re: Bit sharpener in reply to Don-Wi, 03-01-2013 18:13:55
Don-Wi said: (quoted from post at 19:13:55 03/01/13) I bring ours to work, where we've got a Darex. Tons better than the drill doctor, but tons more money too. I can do just about all of our drills, which is 2 drill indexes, 1 of them containing fractional, number, and lettered drills, in less than an hour. Probably closer to a 1/2 hour.
Only three left in stock!!! Better act fast. This is the light duty unit so it is only $1600.
http://www.amazon.com/Darex-Light-Duty-Drill-Sharpener-Model/dp/B00099E1ZW
This just in
Guess who make the Drill Doctor? That is correct, Darex!
http://www.drilldoctor.com/index.php?option=com_content&view=article&id=2&Itemid=16
This post was edited by sflem849 at 16:29:36 03/02/13. |
| to_many_irons
03-01-2013 17:56:54
24.224.192.21
| for me the best thing since sliced bread !!! |
| Retired Farmer
03-01-2013 17:51:34
207.200.116.12
| I bought a Drill Doctor years ago. Does up to three quarter inch. Keep saying I am going to get it out of the box someday and use it. Have a bunch of dull bits that could use sharpening. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
