Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Rosebud tip
Mike M
03-01-2013 13:43:33
Our rosebud only works right with the pressures cranked up alot. Even with a green shield I still got my eyes welder burned. You must need something darker then for regular brazing.
Stan in Oly, WA
03-02-2013 01:12:14
 Re: Rosebud tip in reply to Mike M, 03-01-2013 13:43:33
No UV rays in oxy/acetylene flame, only infrared and visible light. Are you sure your eyes didn't just get dried out from the heat? With oxy/acetylene welding, shaded glasses are only to block some of the visible light, but a lot of people don't bother with them for using a rosebud---there's no weld puddle you have to be able to see.
Stan
Stick welding
03-02-2013 22:49:31
 Re: Rosebud tip in reply to Stan in Oly, WA, 03-02-2013 01:12:14
Even when setting the flame for cutting, you don't normally wear cutting goggles. I've seen a lot guys do good cuts without goggles but I have real trouble seeing what I'm doing and it really bothers my eyes. With a rosebud you're not usually staring right at the flame. You're watching the piece you're heating up and not melting it.
aarolar
03-01-2013 15:34:30
Huh? You burned your eyes brazing with an oxy/fuel setup?
On topic you are going to need to jack your fuel pressure up to about 10psi when using your rosebud be careful not to exceed 15psi with acetylene. Also be sure you have a good seal between the rosebud and mixing chamber if its able to suck any air in there it will pop bad.
