TractorLinks.com
Tool Talk Discussion Forum
Re: Torch cutting tool
Stick welding
03-01-2013 10:55:13
A magnetic cutting guide is nice accessory to have. I have a cast aluminum one that the tip glides on a lot nicer than a piece of steel. Lining up the preheat holes makes for the best straight line cuts and preheating thicker plate also helps. Off setting the preheat holes is best for bevel cuts. The cut in the video has a slightly rounded edge on one side most likely from too much preheat or having the flame too close. I sometimes use one size smaller tip and a little preheat to get a real nice cut with a thinner kerf. A perfect O/A cut will be cleaner than a sheared cut. On 1/4" and above. I much prefer a cutting torch over a plasma torch.
torch guy
03-02-2013 19:09:20
 Re: Torch cutting tool in reply to Stick welding, 03-01-2013 10:55:13
Sounds like we practice a lot of the same methods stick man. A thin, sharp kerf with a very very slightly sweeping drag lines are always the best looking cuts in my opinion. Not quit as step as a production cut but just a hair.
