Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: Re: help locating rafters
[Show Entire Topic]  [Return to Forum]
Billy NY
03-01-2013 09:10:40
72.226.79.200
Conventional framing, you have about 1 1/2" of each member to find center on, for a fastener to be installed, and if its a truss, it could be southern yellow pine, which is a bit hard and brittle, miss that center and the fastener will pull out prematurely. I have aligned center by sweeping from each side of the suspected framing member, making a mark on each side and centering between them, yet I do not recommend blindly attaching something a person will sit on, into framing I cannot see first, its asking for trouble, now or later.
A.) check to see the size of the member will support the load between the span, which is the swing and how many people, there has to be a reference for lumber, its an engineer function, but it would seem like overkill, overthinking, but also a safe thing to do, that is entirely up to you.
B.) if after reinforcing, doing some investigating, confirm you should have enough strength and that the fasteners will hold in what you have and remember the fasteners are going to be either in shear and or tension, one had best select the right fastener, do not use deck screws and or even some kinds of cheap lag screws, they can be pot metal, never trust them unless there is a astm designation and made by a reputable mfr.
C.) I got a call from a customer to repair a commercial overhead door at his building and what I determined was mentioned above, I have photos somewhere in this pc, lag bolt fastener off center, split the bottom chord of the truss, the whole thing could have come down, killed or seriously injured someone. Trusses are really not meant for extra loading anyway, especially from the bottom chord, yet people do it all the time, usually not excessive weight, likely no problem but that bottom chord carries most if not all the load and one has no idea what the limits are unless its calculated, checked out and confirmed by same. My fix was to open up the area, you should do the same, and inspect what you have. In this case I decided to make hangers out of steel angle iron, which spanned a couple of trusses each side, I drilled holes and installed threaded rod, used an angle over and under the bottom chord and literally clamped both angle iron sections to the bottom chord, this afforded me the rest of the attachment and firmly stiffened up the entire assembly holding that door, it eliminated further compromising the framing above.
Purely up to you how you do it, blindly nail or attach without inspecting the existing framing opens the possibly much further of what ever it is you are attaching, to fail, which while sitting in the swing could cause serious injury, do a seatdrop from that distance, you could cause a spinal injury, compress a vertebrae, I'm no doctor, or licensed P.E., just common sense to do the right job.
[Reply]   [No Email]
Tuckermac
03-01-2013 10:31:24
152.26.228.28
 Re: help locating rafters in reply to Billy NY, 03-01-2013 09:10:40
Thanks a lot. I think I will brace between rafters and then bolt to that. Probably use screws to fasten the braces between the rafters. I would think this would share the load and be firmer as well.
[Reply]  [No Email]
Billy NY
03-03-2013 05:40:50
72.226.79.200
 Re: help locating rafters in reply to Tuckermac, 03-01-2013 10:31:24
Again use care with any screws, most common modern screws used for wood framing you'll find are not rated for any shear loading, and are likely not to have much in tension. However, you may be able to source wood screws that will suffice, well worth finding the fastener that has some loading capability in shear, tension and has threads with the best pull out or failure values. I would assume you could "beef up" the framing, for that garage door repair I mentioned, I liked being able to span a few trusses to spread out the load, and being able to clamp down on that bottom chord, eliminated any free play, the swing will impose some kind of rotational forces, so I would want to anticipate that and incorporate what makes sense to stiffen and safely secure it above, I kind of overthink some things, and like overkill and substantial safety margins, especially when it comes to things like these.
[Reply]  [No Email]
cannonball
03-02-2013 04:41:44
98.20.39.81
put you a 2x6 at bottom of rafters and then get an eight ft 4x4 and put on top of rafters, toe nail 4x4 and long eye bolts..this will spread the load to more than 1 or 2 rafters, double nut eye bolts
[Reply]  [No Email]
Zachary Hoyt
03-01-2013 10:41:03
184.12.76.132
If you use eye bolts I would recommend nylock type nuts, I hung a swing with regular nuts and one came unscrewed after a while. With the lock nuts it has been years with no problems.
Zach
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
