TractorLinks.com
Tool Talk Discussion Forum
Re: Explain this crack
Ken-Pa
02-28-2013 21:39:31
Here"s my guess . It looks like metal stress wrinkles from bending the pipe . Could it be metal fatique plus vibration thru time causing the crack ? I"d try grinding that area bright & shiny plus cutting a V in the crack . Set up your mig welder , heat that area with your torch & then make small tack welds & finalizing it with a good solid weld . Also it may help even more to drill small holes at each end of the crack before welding so the crack won"t go any further . I had a similar situation with the rear blade for my tractor . The PO (my Uncle)had used it roughly with no care at all. HTH ! God bless , Ken
