Don Anderson
My house is eight years old and I have a three way switch connected to an outlet that has never worked. Forgive me if I get the ground terminolgy wrong but when I connect my fluke meter to the bare wire at either switch with the switch on I have 121.6 volts from all three screws between the bare wire and the other three wires. At the outlet, I have the same voltage between the hot wires and the bare wire but only 62 volts between the white and black wires and the red carrier carrier wire. Both switches are lighted so I assume that I am getting just the voltage from whatever lights the switch. I would like to get this fixed but I guess I have put up with it for 8 years so it would not be a real big deal if I can not get it working correctly. Thanks for any help.
