TractorLinks.com
Tool Talk Discussion Forum
Re: 3 way switch
dr sportster
02-27-2013 08:55:28
The discolored screw [black or copper ] is the point terminal. If you change out the 3 way sw make sure you first place the wire from the discolored screw on the same discolored screw on the new 3way sw. The other two don't matter where they go. Other than that advice I'm not really following you. What is the voltage to ground [bare wire or metal box ] from the black wire on the receptacle? How do you know it was controlled by the 3way switch if it was never working? Note ;when you have a red wire on a receptacle and black on the other screw same side you must break off the small tang separating the two right side terminals. With ground down right side is hot left is neutral.
All the grounds should be on green screw terminals at the device and nothing else.
