Part Time Pete
I'm looking for wet bolts for the tie rods on one of my running gears. Does anyone know where I could get them. I think that's what they're called - they're a 5/8" x 2" bolt with a grease fitting in the end.
Thanks
(quoted from post at 16:03:43 02/26/13) I'm looking for wet bolts for the tie rods on one of my running gears. Does anyone know where I could get them. I think that's what they're called - they're a 5/8" x 2" bolt with a grease fitting in the end.
Thanks
drill & tap ought to get 'er done.
Either TSC or Northern Tool used to carry bolts for trailer spring equalizers and shackles that were greasable, not sure of size. Also Mcmaster-Carr: "wheel axle bolts". HTH
In a pinch, I have made them - drill out though the center lengthwise, drill through the side to meet the first hole, and tap the first hole to fit a grease fitting. Have worked in several applications.
